Ignition switch
Shawn, Oh.
10-06-2001 20:01:52
Can anyone tell me what the proper ignition switch looks like on a TO30? Do the lights work off this? Thanks to all the people who have wrote to me with their help. Shawn
PJ Fenner
10-06-2001 22:20:04
 Re: Ignition switch in reply to Shawn, Oh., 10-06-2001 20:01:52
My ignition switch has a position for ignition only, lights and ignition, lights only. And I forgot the OFF position. These switches can be purchased new.
DAN
06-12-2002 12:03:29
 Re: Re: Ignition switch in reply to PJ Fenner, 10-06-2001 22:20:04
You say these switches can be purchased new? I am in need of one and cannot find one with the 4 positions like the original. Do you know where these can be purchased?
Ray,IN
10-06-2001 20:34:40
The switch is quite similar to other push types, only mounted upside down. It is located just below the battery. You may connect the lights connection to the hot side of the switch, as the other side is hot only when the starter is engaged. Run the wire through the ignition switch if desired, to avoid accidental operation resulting in a dead battery.
