Holding down arms
Curt in Mi.
10-05-2001 18:50:16
Does anyone know of a way to hold the 3pt. arms in place when you're using a loader without using the old chain around the axle method. This is bad on newly painted or restored tractors. I have a freeman loader and I'm going to use the existing hydraulic system, until I can engineer a live one thats doesn't work off the front pulley. Thanks, Curt
Scott Morrow
10-13-2001 19:06:36
 Re: Holding down arms in reply to Curt in Mi., 10-05-2001 18:50:16
Hi I have a set of factory hold downs for a freeman loader that I would be willing to get rid of please email me if intrested.
Tim
10-26-2001 05:11:53
 Re: Re: Holding down arms in reply to Scott Morrow, 10-13-2001 19:06:36
Hi Scott,
How much for those hold down arms?
Tim
Duner Wi
10-06-2001 06:10:03
On my 3 pt. wood splitter I made a telescoping device between the top link mount nearest the tractor and the other end to the drawbar. It is made out of sq. tubing with a series of holes in it . I position the wood splitter height and drop a pin in. Now the arms will not come up or down. Also the spring will compress if the load gets great enough such as when you are plowing and hit a rock. This should work for you also and it saves on paint.
Ray,IN
10-06-2001 20:26:55
 Re: Re: Holding down arms in reply to Duner Wi, 10-06-2001 06:10:03
Consider using an adjustable top link and the drawbar. Raise the TPH and drawbar to top limit, adjust top link to allow it to be pinned to drawbar while at top limit.
