Help! Low Oil Pressure!
Tyler
10-03-2001 15:39:37
Just went down and started my 51 TO30 and instead of registering 20lbs. pressure like it always has, I only have about 5lbs. I'm running straight 30wt.
what would cause such a sudden drop? Oil levels' fine. I don't know how long ago the engine was rebuilt or if it even was but it has been fine for the 2yrs I've owned it. Any advise welcom.Thanks
ErnieD
10-05-2001 16:35:04
 Re: Help! Low Oil Pressure! in reply to Tyler, 10-03-2001 15:39:37
Dirty/Packed up oil filter? Don't remember how the oil bypass works on this motor. Worth a look see if it has been awhile or if it was cold last night.
Ray,IN
10-03-2001 19:40:14
Don't be alarmed. The stock gauges are not always accurate. As long as some oil pressure is regestering and the oil level is ok, adequate lubrication is occuring. Have you changed the oil recently? Sometimes the oil will drain from the capalliry tube and allow air to enter, this will cause the gauge to act weird until the oil forces the air out. Try loosening the nut on the back of the gauge until oil seeps out. That's my brainstorm for tonight!
Tyler
10-05-2001 16:08:07
 Re: Re: Help! Low Oil Pressure! in reply to Ray,IN, 10-03-2001 19:40:14
Thanks, Ray. I'll give it a shot this weekend
Fred OH
10-08-2001 08:35:11
 Re: Re: Re: Help! Low Oil Pressure! in reply to Tyler, 10-05-2001 16:08:07
Tyler, If the instructions the other fellows gave you don't work, I'll give you one that works occasionally and has made me smile a time or two. Start her up and take a wrench and smack the underneath part of the dash a little. Sometimes the old De Arsonval movements get sticky and you have to jar it a little in colder weather. L8R----Fred Martin, Greenfield, Ohio
