To-30 will not start
chris
09-29-2001 11:51:38
I have a to-30 that I recently pulled out of the woods I replaced the points, plugs, wires, coil and voltage reg.I put a rebuilt carb on it with a new manifold.I have an I@T shop manual that I used to get it wired and the time set. all it will do is turn over like it is not firing, also gas will run out of the carb.
John, IN
09-29-2001 19:16:58
 Re: to-30 will not start in reply to chris, 09-29-2001 11:51:38
The first thing I would do is put back on the old carb. Gas running out is not good.
Ray,IN
09-30-2001 04:31:01
 Re: Re: to-30 will not start in reply to John, IN, 09-29-2001 19:16:58
John is right. Sounds like the carb float is stuck down allowing gas to free flow, thus flooding the engine. The first thing after fixing the carb is to insure that there is spark at the plugs, if there's no spark everything else is immaterial. If indeed there's no spark, start at the dist and follow the electrical route, insuring each part/connection is ok to the plugs. BTW, it would start anyway but remember these old tractors are pos gnd.
