T0-20 ground
dw/tx
09-19-2001 17:58:03
Where does the positive cable connect on the chasis? At present mine is connected to the back of the dash panel. I'd like to replace the battery cables and get a new wiring harness. Thanks, dw
Ray,IN
09-19-2001 19:40:55
 Re: T0-20 ground in reply to dw/tx, 09-19-2001 17:58:03
That's where the pos. cable is connected originally. To restore to original condition it should be replaced there. For best connection, run to a starter mounting bolt.(requires longer cable) When replacing the battery cables use "0" gauge cables, the 6ga. cables made for 12v systems are too small to carry the current needed for a 6v system; that's one reason why you hear complaints of poor starting in cold weather. A 6v system will perform just as well as a 12v system if properly maintained.
marlowe
09-20-2001 09:20:27
 Re: Re: T0-20 ground in reply to Ray,IN, 09-19-2001 19:40:55
right on ray you hit it right on the head IF PROPERLY MAINTANED
marlowe
09-20-2001 09:19:18
