TO30 rims
mike
09-16-2001 12:41:34
Im looking at a TO30 to buy. The right rear rim has been replaced with an almost new one but it is a 12 inch, the left an 11 inch rim. The owner says its no problem. Is it OK to run like this? Both tires are 12 4 28's. Thanks
Ray,IN
09-16-2001 21:02:56
 Re: TO30 rims in reply to mike, 09-16-2001 12:41:34
It's okay to operate with one wider rim as long as the tire/rim doesn't rub on anything. Both are the same diameter. Actually the rim should be the same width as the tire. If you decide to replace the 11 in. rim, look to Miller Tire under the parts suppliers listing here.
