Weird TO35 problem
Jim McCary
09-14-2001 17:43:16
My father has a TO35 that he rarely uses. Recently the distributor started trying to climb out of the block. It will bend the keeper plate up until the gear loses contact with the cam and dies. I have never heard of a problem like this, and none of the local mechanics are familiar with older tractors. I am at a loss. I double posted on the main forum in hope that anyone familiar with the Continental Z134 will see and have an answer.
Thank you,
Jim
Duner Wi
09-14-2001 18:53:23
 Re: Weird TO35 problem in reply to Jim McCary, 09-14-2001 17:43:16
The only thing I can think of is the shaft is dry and needs some oil. I have a TO 20 and am putting new bushings in my dist., the shaft is only wore 1/2 thousands but the bushing has lots more. My dist. has an oil plug on the side of it but It looks like it would take some time for the oil to reach the shaft.
Ray,IN
09-14-2001 20:31:13
 Re: Re: Weird TO35 problem in reply to Duner Wi, 09-14-2001 18:53:23
Yep, Duners' right! the thrust bearing is worn out. Rebuild the dist. When the owners manual says to lube per schedule there's a reason, but most folks ignored it.
