Massey Ferguson 135 front pulley
Travis Most
09-05-2001 18:59:02
Just wondering if anyone has seen a front pulley to go on the 3 cyl. perkins gas engine that has tapped holes for mounting a coupler for a front hydrolic pump. And where can I get one!? Thanks.
Jerry in Id.
09-06-2001 16:23:20
 Re: Massey Ferguson 135 front pulley in reply to Travis Most, 09-05-2001 18:59:02
Travis
You didn't specify if you wanted a 3 or 4 bolt configuration. Here is the Massey p/n for the three bolt configuration that is used on the MF20 3 cyl Perkins engines: prior to engine s/n 152 UA 25587A it is 734 628 M1, Perkins #31147784, and for engine s/n 152 UA 25587A and up it is 734
627 M1, Perkins # 31143733. You might want to check with your local MF dealer about this configuration because my parts book is misleading.
However these are the two P/N that are called out. Hope this helps
Jerry
Ray,IN
09-05-2001 20:07:06
This is the best I can do for you Travis, the guys on the Massey Ferguson board may have more information.
