To 20 solenoid
cbto20
09-04-2001 10:47:16
The to 20 I recently purchased was converted to 12 volts. The man just put a new solenoid on it and it was working fine. I tried to start it yesterday and it would not start. It kept trying to start even when the key was removed. Someone told me it sounded like the solenoid was sticking, and to check the wiring. I don't know how it is suppossed to be wired or if this could be the problem. Can anyoned give me some advice or even a schematic on how it should be wired?
thanks
DonB
09-05-2001 21:14:27
 Re: to 20 solenoid in reply to cbto20, 09-04-2001 10:47:16
Large guage wire from the negative battery post to one of the large terminals on the solenoid. Another large guage wire from the other large solenoid post to the starter. Ground strap from battery positive to the chassis.
A small guage wire from the battery negative the key +. Wire from the key ign to the coil. Wire from key S to small terminal on the solenoid.
