NEED HELP!!!!!!!!!!!!!!!!
Jone
08-31-2001 10:13:19
I`v got a cracked bottom pan (The pan under the engine, in Norwegian it is Bunnpanne, so it was directly trancelated) A machine shop tryed tho weld it for me, but no luck (only got worse)do you guys have any good ideas. Or are there anyone in Norway Who got a Replacement Pan?????
Jone Tveitane
Stavanger, Norway
93816673
Pete Tatham
09-01-2001 01:46:24
 Re: NEED HELP!!!!!!!!!!!!!!!! in reply to Jone, 08-31-2001 10:13:19
Jone, You don't say what tractor you need the sump for. Your best bet is to try and obtain a used sump from a scrap yard. If you have no luck in Norway, try Richard Pocock, based in Dorset, England, he has lots of good quality new and used tractor parts and will no doubt be able to help you. His e-mail address is RJB [email protected] Hope this helps,
Pete.
Jone
09-03-2001 10:04:22
 Re: Re: NEED HELP!!!!!!!!!!!!!!!! in reply to Pete Tatham, 09-01-2001 01:46:24
It is a 1950 TEA With the plug in the pan pushed inn, and it has cracked around the welding!!!!!:(
