TO-20 clutch
TO-20
08-29-2001 09:51:47
Well i think the clutch is gone on my 20 can't even slow down the drive train to put er in gear have to just jumper in and i know that's not good. I have tried adjusting the clutch pedal by loosening it and readjusting. just doesn't do any good. any advise guys.
Kurt
Ray,IN
08-29-2001 21:00:17
 Re: TO-20 clutch in reply to TO-20, 08-29-2001 09:51:47
Are you saying the clutch doesn't disengage? If that's the problem, just tie her to a large tree; depress pedal and slip the clutch to remove the rust/crud holding it to the flywheel. I had to do this when I first got my TO30; don't get the clutch too hot. The clutch will break free if that's the problem, if not you'll just dig two holes. That's my way. BTW, clutch adjustment is 3/16" free travel between pedal and footpeg.
