What is the correct oil level for the stearing box?
Tim
08-26-2001 12:24:42
Should the oil level come up to the fillar plug on my TE20, if not what is the correct level?
Thanks
Tim
Ray,IN
08-26-2001 21:47:44
 Re: What is the correct oil level for the stearing box? in reply to Tim, 08-26-2001 12:24:42
Oil level should be to the center of the sector shafts(arms coming out of each side). Use trans oil=80W straight mineral oil(no additives).To remove the old oil, use a hand suction pump, for there's no drain hole.
DRIZLER
08-29-2001 07:27:43
 Re: Re: What is the correct oil level for the stearing box? in reply to Ray,IN, 08-26-2001 21:47:44
You will likely find that the leather seals are leaking where the arms are comining out of the box. I filled mine with white lithium grease 5 years ago and just topped it off again the other day. Its real slow to leak out and steers just fine at -25 degrees plowing snow. Changing those seals is a real pain-in-the-pants.
