TO series ???
Greg Pownall
08-24-2001 16:11:20
After taking my time, I just located a good restoration project. I cannot find the serial number listed within the Ferguson site. Can anyone help me, the serial numger listed right above the stering wheel in the original plate is,, TO 42705.
Also by chance it has a loader and only a portion the name plate is attached, but the lower part says F500,, Any clues ?
Thanks much to all, I enjoy this site alot.
Cheers,
Greg
teadave
08-27-2001 13:00:45
 Re: TO series ??? in reply to Greg Pownall, 08-24-2001 16:11:20
i can't help on the loader, but your to20 is a 1951.
Paul in NM
08-25-2001 11:43:10
Greg - the problem with the SN lists on this site is that they give only the starting number for any particular year. You have a 1951 TO-20, I believe. You might also look at the link listed below for some good information. Click on "Tractors."
Good luck on your project.
Paul Nelson
Greg P.
08-25-2001 13:57:13
 Re: Re: TO series ??? in reply to Paul in NM, 08-25-2001 11:43:10
Paul,Got it. Thanks for the good link.
Looks like i'll be stopping there frequently.
Thanks again,
Greg
dennis
08-24-2001 17:11:11
check 'serial numbers' to the left of this page. looks like a 48 TE20.
Greg P.
08-24-2001 18:01:53
 Re: Re: TO series ??? in reply to dennis, 08-24-2001 17:11:11
Dennis, Thanks, here is some more confusing things. Under the seat on the right side, the model is marked "TO 4024" and stamped around the block it is marked "TO 3551". What is going on here ?
Bill Mc
08-24-2001 19:36:38
 Re: Re: Re: TO series ??? in reply to Greg P., 08-24-2001 18:01:53
Hi Greg
Your serial number seems to be wrong.The TO-20 is listed up to around TO39000. The TO-30 starts at TO60000. Recheck you number,It could be TE42705. The numbers TO 4024 and 3551 are part numbers.
Good Luck
Bill Mc
Greg Pownall
08-25-2001 10:52:31
 Re: Re: Re: Re: TO series ??? in reply to Bill Mc, 08-24-2001 19:36:38
Thanks for the follow up. The serial # is clearly, TO 42705. I saw at the bottom of the serial plate that this Fergy was made in Detroit. Why can,t the number be found in the lists shown at the left ?
Thanks once again,
Greg
