TO-30 Clutch Adjustment
Jim
08-19-2001 18:31:31
Can someone tell me where the adjustment is on my TO-30 so I can see if there is any adjustment left.
Ray,IN
08-19-2001 21:22:47
 Re: TO-30 Clutch Adjustment in reply to Jim , 08-19-2001 18:31:31
Put a bar into the hole in the clutch operating rod, and while holding it steady, loosen the clamp bolt on the clutch pedal shaft. Turn the chaft clockwise until and engagement with the release bearing is felt,then adjust pedal so there is 3/16 in. between the foot peg and the clutch pedal and tighten bolt. You may buy a owners manual reprint from a MF dealer that covers normal maintence work. I've used mine until its about worn out.
