TE20 oil pressure?
rod
09-20-1999 07:43:57
MY 52 Ferguson TE 20 has good oil pressure when just started but after a few minutes the pressure drops to about 5 pounds. The tractor starts and runs good what is correct oil pressure and does anyone know what number or type of correct oil filter to get.\\
thanks
rod
Ernie
09-23-1999 14:41:48
 Re: TE20 oil pressure? in reply to rod, 09-20-1999 07:43:57
Probably wide bearing clearances. We had a TO30 with the same symptoms. Rebuilt oil pump with no positive results. I would suggest thicker oil and as long as there are no bearing knocks use it. Our TO30 ran 4-5 years mowing and blowing corn wide open. One morning at idle it was knocking and we traded it in on disk.
If you got the time and inclination drop the pan and plasti gauge the insert clearance.
