What to do when you hit a hive?
Frank (VA)
07-26-2001 13:56:03
Friends,
I was mowing with my TO-20 last weekend and took the top inch off a hive that was in the ground. I was probably going faster then I should have, which put me a good ways past the hive before the yellow jackets figured out who the culprit was.I don,t think going slower would have helped me see that there was a hive there in the first place.
I had a friend who got swarmed once while mowing and was hurt badly when he jumped off the tractor. Any opinions on what is the best thing to do in this situation?
Thanks
Frank
Fieldman12
07-28-2001 05:51:22
 Re: what to do when you hit a hive? in reply to Frank (VA), 07-26-2001 13:56:03
I don�t think there is much you can do but get away as fast as possible and try to find some type of protection.
I was bush hogging once with our old Ferguson TO-20 and hit a hive of yellow jackets and got stung 17 times. As soon as I got stung twice and seen more coming I put the tractor in rode gear and tried to get away as fast as possible but believe me they can keep up with that tractor running across the field wide open. I drove probably 350 feet and decided to put the tractor in neutral and jump off because they were stinging me left and right. I headed for our little pond that is only about 3 1/2 deep and jumped in. This was the best thing I done to get away even though my feet was in about a 1 1/2 of mud at the bottom. Later, that night I fixed them, I poured gas around their hive and lit it.
Later,
Fieldman12
Phil (VA)
07-31-2001 11:30:52
 Re: Re: what to do when you hit a hive? in reply to Fieldman12, 07-28-2001 05:51:22
Best advice is cut engine and jump off as quick as possible and run like H___. Get tractor later; stings don't hurt it. Pour gas on hive at night (when they are all home) and don't have to light it as the gas kills 'em all, with or without the fire. We had hive in floor of storage building this year. Got me before I knew it was there. Couldn't use gas on that of course; had to hit them with spray bomb which is not as thorough.
If you close your eyes really really tight, they can't see ya.
07-27-2001 22:31:58
B-)
John
07-27-2001 16:53:05
My Grandfather once plowed up a bumble bee nest. He said the thing to do was pull the throttle all the way back and let the air off the fan keep them off you. He was using a Ford 3000 at the time.
Frank Biscardi
07-27-2001 18:37:30
 Re: Re: what to do when you hit a hive? in reply to John, 07-27-2001 16:53:05
I think staying with the tractor and speeding up makes more sense then jumping off. The tractor in 4th gear probably goes faster then I can run anymore. Also, getting stung a couple hundred times is no worse then getting run over by the bushhog once.
Frank
RedneckMatt
07-27-2001 06:22:22
This happened to me once, I have a 9-N. Was a stupid thing to do but I shut the switch off jumped off the tractor and ran like mad. Never got stung but new problem was how to get back on tractor that was only a few feet from pissed off yellow jackets. Had to wait till after dark to go get tractor.Just be careful I don't think there is a good answer to this guestion.
dennis
07-26-2001 16:37:56
I got swarmed one day. Fortunately my pickup was only a hundred yards away. Ran like heck, jumped in, only 6-8 got in with me. Squashed them as quick as I could and called for help on the cellphone. Got stung about 20 times. Eyelids, lips were the worst. Got really sick but I toughed it out - didn't go to the Dr. Knew I wasn't allergic so I didn't worry (foolish, was I??). But I was really sick for a couple days !
Hope I never do that again !!
