TO20 ignition
ric
07-22-2001 08:41:41
Now that I've found my Harry Ferguson to be a 1950 TO20, I don't know how to tell if the ignition is 6volt or 12volt. There was no battery so I can't tell by that. Any help will be greatly appreciated.
Phil (VA)
07-23-2001 11:20:12
 Re: TO20 ignition in reply to ric, 07-22-2001 08:41:41
If it has an alternator you know it is 12 volt. The reverse isn't true, but as someone said, a generator probably means 6 volt.
dennis
07-22-2001 18:56:49
if you've got a 6 v battery lying around, put it on and try it, if if won't start and has no spark or really really weak spark you'll know it's a 12v coil
Duner Wi
07-22-2001 16:57:39
Check a light bulb or two. The generator #s may tell us also. Some times the voltage reg. will be stamped on the underside 6 V Pos .
Bill Mc
07-22-2001 12:20:26
Hi RIC
Most likely if it has a generator it is a 6 volt.
Bill Mc
