Lift arms won't raise
vtdave
07-20-2001 18:58:07
I'm having a problem with my hydraulics on my TO-35. I changed my trans-diff-hydraulic oil because there was water contamination and the 3 pt was not raising well when warm. I used a good mineral based oil as per the manual. Problem is now it won't raise at all if there is any weight on the arms. What's the problem? I had hoped the oil change would help!
Bill Mc
07-21-2001 07:34:12
 Re: Lift arms won't raise in reply to vtdave, 07-20-2001 18:58:07
Hi vtdave
The first thing I would check is the safety relief valve.Remove the right inspection cover and look for any splashing or spraying oil, this could indicate a stuck safety valve . Also look at the hyd cylinder is it leaking oil? My best guess is that your hydraulic pump needs a good cleaning and inspection.Best Wishes
Bill Mc
