Oil fo TED20
Mike U
07-19-2001 10:06:24
Is 30 weight mineral oil the correct oil for the gearbox/diff/hydraulic system as well as for the engine on my TED20. Also do you fill the diff/hydraulic system/gearbox all from the same point next to the gearlever?
Thanks
Mike
marlowe
07-20-2001 08:13:28
 Re: Oil fo TED20 in reply to Mike U, 07-19-2001 10:06:24
i use 15-40 ser3 shell rotella in all engins from my lawn tractor to a 350hp. cummins in my dump trucks i never heard of minarel oil in the engine unless you mean non.det. oil witch some is minarel oil like i said other times its your tractor so you sure can use what you want but the rear end is for sure 80-90 min. ray from ind. and big dean i think will agre hope this helps
Mike
07-21-2001 03:15:34
 Re: Re: Oil fo TED20 in reply to marlowe, 07-20-2001 08:13:28
Thanks Marlow, I was not suggesting you were wrong I simply wanted to get as many opinions as possible, thats all,
Thanks
Mike
marlowe
07-19-2001 18:25:48
80-90 mineral oil in rear end .yes it has 1 fill point by the shift lever. dont use mineral oil in the engine. i use 15-40 year a round in the engine
Mike
07-20-2001 03:19:57
 Re: Re: Oil fo TED20 in reply to marlowe, 07-19-2001 18:25:48
Are you sure? only a reliable source advised me to use to 30 weight mineral oil for the hole tractor. Apparantly the mineral oil protects the gaskets, of have I received duff info
Thanks
Mike
