Live lift on TO 20
Russell Frazier
07-08-2001 18:38:34
dose anyone know of a kit to convert my TO 20 to a live lift or know of a good device to put on the hydrolics to keep the position better,mine keeps it good after an hour of running but until then it is very hard to bush hog without the level constantly changing.
Jim-PA
07-08-2001 19:45:13
 Re: live lift on TO 20 in reply to Russell Frazier, 07-08-2001 18:38:34
No way to make the hydraulics live without mounting another pump on the front to run off the engine. They make them to run of the PTO too but you don't want to use it cause you need that for running implements.
The Zanethang will give your current hydraulic system position control. Or you could use limit chains to keep the brushhog at a set level.
Here is the link to the Zanethang.
