TO30 leaking oil from air vents under side of the tractor
Joe
07-07-2001 20:39:10
Is there away to stop the leak without going into the transmission case for it?
Ray,IN
07-08-2001 21:20:32
 Re: TO30 leaking oil from air vents under side of the tractor in reply to Joe , 07-07-2001 20:39:10
Assuming you mean the small hole with the cotter key in it,the hole is to drain away the oil leaking through the front transmission seal. Splitting the tractor is necessary to replace the seal.
