Overcharging Problem
Pete Tatham
07-03-2001 01:41:16
At just about 3/4 throttle the ammeter on my TEF swings right over to show a charge of 30 amps. Thinking that the voltage regulator was faulty I changed it for a new one, but still the same problem. The battery is fully charged. I'm no auto-electrician, so can anyone hazard a guess as to why this is happening and what's faulty?
Thanks in advance for any assistance.
John
07-04-2001 16:45:20
 Re: Overcharging Problem in reply to Pete Tatham, 07-03-2001 01:41:16
If your voltage regulator is OK I would look at the ammeter, or may be just may be there is a short under load. Look at the wiring in the dark while it is running. I just changed mine over to 12 volt alternator. You can get all the wire and terminal ends at your local hardware store. Good luck.
