TO-20 Master Control Spring Adjustment
David Waymann
07-02-2001 20:27:34
Hi All: Can anyone tell me if adjusting the master control spring with a bush hog attached is a problem--the manual says to put a plough in the up position? Can anyone tell me what symptoms might be present if the tension on the spring was too loose or too tight? Thanks in advance, David, MI
Ray,IN
07-03-2001 21:03:37
 Re: TO-20 Master Control Spring Adjustment in reply to David Waymann, 07-02-2001 20:27:34
No problem! Any load will work,just adjust all end play out of the spring without preloading it. Too loose will allow oil leakage, too tight will prevent the "overload" valve from opening as designed upon striking heavy clay or underground obstruction. That's why the plow is mentioned,but as I said, any load will work to pull the linkage tight.
