Tea20 bore question
john Ont
06-28-2001 18:35:54
how do i know what the bore on the engine of my tea20 is?
Vaughan John Williams
06-29-2001 20:17:28
 Re: tea20 bore question in reply to john Ont, 06-28-2001 18:35:54
As mentioned earlier if your TEA 20 had a serial number below 172501 then it is a 80mm bore.
However, if you haven't got a serial plate or it has been damaged so that you can't identify your serial number then there is an easily visual check you can make.
With 80mm bore engines the water pump is bolted to the engine block. If you look at the engine from the side you will be able to sight a small gap between the engine and the water pump.
The 85mm bore engines have a water pump built into the block and no such gap is visable.
Regards
Vaughan
Pete Tatham
06-29-2001 02:47:18
John , The 85mm bore engine cut in at tractor no 172501 on 22.1.1951.
Pete.
manuel
06-28-2001 23:16:48
As far as I know there was the 80mm to start with.
Then around 1951 it went out to 85.
Is urs petrol or diesel?
paul
06-28-2001 21:54:00
85 mm
