Need Help
Tyler
06-26-2001 19:23:47
What's the proceedure for changing the gaskets for the cover plates(?) on the sides of the trans., hydraulic pump casing or whatever it's called. The one doesn't look like a problem but the other one with the lever sticking out of it scares me. I hope I've explained this right.
Another thing; my oil-bath air cleaner is rusted through. Anyone know where a replacement could be procured? Would one from an 8n work?
Thanks in advance for any help you guys can furnish.
Tyler
Pete Tatham
06-27-2001 00:50:09
 Re: Need Help in reply to Tyler, 06-26-2001 19:23:47
Tyler,
Changing the gaskets is a simple procedure, all you need to ensure is that the inner end of the PTO lever is correctly engaged. If you have any doubts, get a workshop manual where everything is explained with photos and simple text. It makes the job 100% easier if you have an idea as to what you are doing.
Hope this helps,
Pete.
Tyler
06-27-2001 11:30:50
 Re: Re: Need Help in reply to Pete Tatham, 06-27-2001 00:50:09
Thanks, Pete. I have a manual but it's missing the section that explains what I'm doing, of course. I'll make sure I keep the lever lined up.
Tyler
Stephen
06-28-2001 00:32:36
 Re: Re: Re: Need Help in reply to Tyler, 06-27-2001 11:30:50
If you pull the cover off with the dip stick and have a look in with a torch and the oil level is low enough you can clearly see the engaugement of the lever and then you can be sure you have the engaugment correct upon reinstallation. I find it pays to put a bit of goo on the threads of the lower bolts as the oil will tend to find its way out along the threads of the bolts.
Tyler
06-28-2001 18:39:14
 Re: Re: Re: Re: Need Help in reply to Stephen, 06-28-2001 00:32:36
Thanks Steve and Pete, because of you two everything went well.
