Sediment bowl
Jeff Groves
06-26-2001 08:43:10
I have a 52 TO-30 and I can't get the sediment bowl loose. Any ideas to how I can unscrew the bowl without breaking it? I am glad I found this site.
Ray,IN
06-26-2001 20:51:50
 Re: sediment bowl in reply to Jeff Groves, 06-26-2001 08:43:10
Apply penetrating oil/wd40 etc. to the threads to minimize breakage. It is normal RH threads, but I have to use pliers to loosen mine if it's been a while. The glass will stick to the cork gasket, so you may have to play with it to avoid tearing the gasket. I reinstall it finger tight but still must grab the pliers each time I clean the bowl and strainer. I use carb spray cleaner on the strainer to remove any varnish and gummy stuff. Replacements are available if you break it.
