Okay.....why is this thing leaking gas??!!!
Jim
06-26-2001 06:04:18
First of all, many thanks to David, William, Ray, and others who have been offering suggestions for my ongoing TO30 problems. I'll certainly try your suggestions. In the meantime here's another question. There is now gas leaking out of the carburetor. Not a lot; just a drip, drip, drip... It looks like it's coming from the area of the choke housing, where the air intake tube is connected. I cleaned the sediment bowl the day before I noticed this. I hooked everything back up, and I didn't see any leakage. I know there is a shutoff valve at the sediment bowl. Do I have to close this every time I shut off the tractor? I've had this tractor for about a year and never closed the valve any other time, and never noticed anything leaking out. I also used to have a TO20 that I don't recall having to do so with. I turned the valve wide open when I reassembled the sediment bowl. Is that too far? What's the scoop? Thanks again.
Phil (VA)
06-26-2001 12:14:43
 Re: Okay.....why is this thing leaking gas??!!! in reply to Jim, 06-26-2001 06:04:18
Brown is correct. However, I suggest you always cut off the sediment bowl valve when you shut down the tractor for any length of time. It's the safe thing to do. A battery spark or cigarette can ruin your whole day, not to mention your barn.
Frank (VA)
06-26-2001 18:56:36
 Re: Re: Okay.....why is this thing leaking gas??!!! in reply to Phil (VA), 06-26-2001 12:14:43
My T0-20 always smelled like gas and was hard to start until I figured out that I needed to shut the fuel valve off when I left the tractor. She smells better and starts faster now.
Frank
william l. brown
06-26-2001 06:27:31
JIM,
leaking gas from the carb would indicate
your needle valve is stuck open. you may
need to overhaul the carb, and reset the
float level.
william
