Work lamp installation for TO-30
Phil Fenner
06-25-2001 20:18:39
Trying to install subject correctly, but have no pictures and am not sure I have all the parts. Does the lamp sit vertical or sideways? Using the wing seems to require the lamp mount sideways, but the fixture has bolt hole for vertical mounting something? Vertical seems more logical but the wing doesn't seem to fit right in this configuration. Any help would be appreciated.
Ray,IN
06-26-2001 20:40:36
 Re: Work lamp installation for TO-30 in reply to Phil Fenner, 06-25-2001 20:18:39
You're right, lamp mounts vertically. Go to the photos page, you may get lucky and find a picture of it. I will email you a picture of mine if you don't find it there. Let me know, Ray,IN
Phil Fenner
06-27-2001 10:44:49
 Re: Re: Work lamp installation for TO-30 in reply to Ray,IN, 06-26-2001 20:40:36
Looked at the referenced pictures but never saw enough detail or proper angle to determine the config. Appreciate your picture if not too much trouble. My big question is where does the wing bolt on, side or top of bracket??
Phil Fenner
07-14-2001 22:23:10
 Re: Re: Re: Work lamp installation for TO-30 in reply to Phil Fenner, 06-27-2001 10:44:49
For those interested, Ray(IN) and myself solved the mystery of my original question. The lamp is mounted with wing so the lamp is horizontal and not vertical as in most Ford pictures I see. The wing fits nicely on the bracket vertical surface with the lamp bolt going in to the bracket thru the wing. Found ads for TO-30 and other authentic pics to confirm this.
