TE20 oil filter question
Ed
06-25-2001 20:13:56
I changed the oil in my 1948 TE20 along with the filter. The filter i installed was a fram C3P which crossed for the wix I took out. The fram filter had a rubber grommet on one end that the wix didn't...I put the fram in with the so called grab handle facing down and the rubber gromet end going in first. Every since i changed the oil and filter my oil pressure varies from 26-28lbs down to 0-5lbs at times. This can happen at any rpm of the motor. Did i install the filter backwards or something? I changed the oil and filter before and never had this happen, afraid to run it much with this oil pressure going up and down all the time...thanks...
Duner Wi
06-26-2001 19:28:20
 Re: TE20 oil filter question in reply to Ed, 06-25-2001 20:13:56
This is only a guess. The Fram flows oil more easily than the Wix. Being the TO20 is a partial flow system I guess more oil is bleeding out the orifice that feeds the Fram filter than was feeding the Wix. I use a Baldwin filter that carries a MF part #.
