TEA2085 Wiring problem.... it won't start!
Rege
09-15-1999 09:36:29
ok here's another interesting mess: my tractor was converted to 12 volt long ago. When I tore the tractor apart I took pictures of the wires in order to put them back properly (this conversion was somewhat unique in that it bypassed the control box - I think). The problem: the ignition switch has 3 connectors - 1 to the dash light & resistor to coil, 2 to the generator then to dash light, the 3rd one should be connected to something but what? to ground? to the control box? The picture I took of this area doesn't show where the wire was connected. If anyone has a fax I could fax you the the wiring diagram if needed. Anyway, it won't start. Help would be greatly appreciated.
Greg
09-19-1999 21:19:42
 Re: TEA2085 Wiring problem.... it won't start! in reply to Rege, 09-15-1999 09:36:29
My TEA2085 is set up 6volt positive ground and is wired 1)coil 2)dash light 3)starter switch
Hope this helps
Greg
