Why dose this tractor hop? PTO?
Greg in Howell
06-21-2001 17:57:25
I Just bought this TO30. The hydrolics work fine other than when I have an implement attached, and in the up possition the tractor bounces. Is this normal?
william l. brown
06-24-2001 13:35:02
 Re: Why dose this tractor hop? PTO? in reply to Greg in Howell Mi, 06-21-2001 17:57:25
my TO-20 did the same thing until i added
some weight on the front end.
william
Frank Biscardi
06-24-2001 19:35:09
 Re: Re: Why dose this tractor hop? PTO? in reply to william l. brown, 06-24-2001 13:35:02
I think the T0-20 is a little light in the front. I have 80 kg (176 lbs) of Belarus suitcase weights on the front fender and about 20 feet(30 lbs) of heavy logging chain. I don't disregard the advice in the other posts, but my tractor wants to hop a little especially with a 5 foot bush hog on the back and I think it is mechanicall intact.
Frank
Jack in NB
06-22-2001 07:50:43
On the 35's - basically the same system - thishop is often caused by a loose master spring on the top link attach point.
If the bracket moves in and out more than 1/16", it's loose enough to activate the internal draft feedback system and cause the hopping.
Adjusting may involve sutting and re-welding (or replacing) the long bolt - they are usually rusted solid. Not expensive - $25 or so US.
Ford Man
06-22-2001 05:26:13
If the lift is bouncing to stay in the full up position , then you probably have a weak pressure relief valve .
Might want to check the archives here or or the N-Board ( the hydraulics are pretty much the same as an N )
Ford Man
John
06-21-2001 19:00:42
I would say it had to do with the air pressure in the tires and or the type of tires.
