Marvell carbs
Larry Babcock
06-18-2001 09:23:31
My '48 TO30 has a Marvell carb which has always been marginal (It's a Marvell!!!). The float does not always work, the idle adjustment has no effect, etc., etc. despite repeated servicing(cleaning). Is it worthwhile to purchase a new carb? Are they any better than the old Marvell?
I can report good results using a magnetic ignition designed by NuRex as a replacement ignition for Model A cars. Good strong consistent spark, no more plugs and points.
David Waymann
06-18-2001 10:48:43
 Re: Marvell carbs in reply to Larry Babcock, 06-18-2001 09:23:31
Larry: I cannot really comment on replacing vs rebuilding your M-S carburetor. I do wonder whether your maintanance has gone far enough back to the source of fuel--namely the tank (rust, sediment, etc.), the screen filter, the fuel bowl/shutoff and the line going into the carb? If you have not checked these areas, I would do so before giving up on you M-S carb--it cannot out-perform what it receives. Good luck, David, MI
