PTO runs all the time with pump
Henry
05-19-1999 18:30:31
Can't run pump without pto output shaft turning.
Is this normal or do I need to open the old gal up and take a look at shift yoke?
kevin
05-20-1999 05:01:26
 Re: PTO runs all the time with pump in reply to Henry, 05-19-1999 18:30:31
The TO-20, TE-20, and the Ford 9N, 2N, and 8N all had this design of running the hydraulic pump off the PTO drive. So, you have to engage the PTO to activate the hydraulics. To sum up, your tractor is behaving as it was designed.
Henry
05-19-1999 18:32:28
I meant to mention it is on a TO20 1950 Model
