TO20...timing question
Ed
06-06-2001 18:25:33
I see there is both retarded timing degrees and also Full advanced timing degrees. Are both individually set? And how is this done? I would assume by rotating the distributor for points fully opened at TDC? Is there anything else to do?
Neal(IN)
06-07-2001 04:12:11
 Re: TO20...timing question in reply to Ed, 06-06-2001 18:25:33
Ed
The timing advance is built into the distributor. If you set the retarded timing (I think its 7 degrees BTDC) then the rest should take care of itself.
I think the manual tells you at what rpm all the advance should be in so if you wanted to check you could run the engine up to that speed and check with a timing light.
Neal
ed
06-06-2001 18:28:12
Excuse me ...it is actually a TE20...1948...Ser# W31748....thanks Ed
