TO-30 Brake Drums
Jim
06-05-2001 19:29:54
Trying to get the Brake Drums off of my To-30, there seems to be two large screws that are holding the Drum to the axle. I even tried using an impact driver to get these out with no luck.
Anyone have a suggestion?
roger
06-06-2001 12:36:46
 Re: TO-30 Brake Drums in reply to Jim , 06-05-2001 19:29:54
Jim;
In addition to what Rod has said, I've used
penetrating oil and a socket-like part that fits
on my 1/2" socket wrench (or breaker bar) and has
the shape of a very large screwdriver blade on the
other end. From memory, the 'blade' is about 3/4"
wide and about 3/16" thick. It worked well.
Roger
rod
06-06-2001 04:33:26
heat the screws or heat the drum around the screws they are very short. If that dont work you may have to drill them. I have none on one side of my TEA 20 the wheel holds the drum on anyway. regards
rod
