Transmission ?
John
06-04-2001 18:08:11
On my TO-20 I just got it has a high low shifter on the left hand side just under the steering box and it works to. I can't find a thing on it in the book. Now has somebody went and added that on from a old Ford? Can somebody shed a little on this for me.
marlowe
06-05-2001 12:35:09
 Re: transmission ? in reply to John , 06-04-2001 18:08:11
mine is on the right and it has 3 speeds put the lever in nutral pull out on leaver a little then up that is a real low low any way it is on mine
Jim-PA
06-04-2001 20:01:49
Sounds like a Sherman over and under drive. They put a lot of them on Fords too. Ask about it over on the 9-N 8-n board. Also the hydraulics on the Ferguson is the same as on the 9-N and 8-N. There are some guys over on that board that know just about everything about the Harry Ferguson hydraulic system. And to answer the question above about getting something to make the hydraulics work when the clutch is pressed in, you are out of luck. You will just have to practice putting shifter into neutral whan you have to use the hydraulics when stopped. Once you get the hang of that you will hardly miss live hydraulics.
John
06-04-2001 20:08:38
 Re: Re: transmission ? in reply to Jim-PA, 06-04-2001 20:01:49
Thanks Jim I need all the help I can get for now. I will get it down pat in time!
