Maintainence Schedule
Frank Biscardi
06-03-2001 17:51:08
I have the original manual for the TO-20.
I was a litle amazed at the maintainence schedule (drain carb once a week, grease every 10 hours etc). I push snow a little, cut some weeds and do some light plowing and hauling. The manual seems directed more to real farmers doing long days on the tractor. Do you all do all of these things as often as is recomended?
Frank
Joe in NY
06-04-2001 17:05:21
 Re: Maintainence Schedule in reply to Frank Biscardi, 06-03-2001 17:51:08
Frank, Use mine same as you but do mow alot in summer. Have 25 acres of evergreens. I run the carb dry when I'm done for the day and always change the air cleaner oil every day or two. Every day if it's dusty. Cheap insurance. I watch the hydraulic fluid and change that at least once a year usually in the spring about May and grease as needed. Just what I do,
Joe
