Carburator
Jerry
06-02-2001 19:42:00
I have restored a 52mod. to30, everything has worked out fine except the carb. I put a kit in it and admit I don't know that much about carbs. in general, my problem is it floods ,won't run at a slow idle, and it leaks all the gas if not shut off. I have tried repeadly to set float ,with no good results, am I in the park or is it something else?
mel davis
06-04-2001 16:37:53
 Re: carburator in reply to Jerry , 06-02-2001 19:42:00
hey Jerry, I have a ferguson 30 that was doing the same thing. I shook the float and found that it had a leak and was not rising because it was too heavy (full of gas. if that is the problem put a sodering iron on the side of the float and turn the float to different angles and the heat will make it spit gas out of the hole. get some soder and fix the hole after you have got all the gas out of the float. note: be careful and not get the iron on the center of the float because it will undo the seam
hope this helps.
mel davis
peterc
06-03-2001 18:56:48
you are in the ball park ,it is a carb problem. check the float pin and float for burrs or binding condition. sounds like your needle valve is not seating.
Jerry in Tx
06-08-2001 18:54:44
 Re: Re: carburator in reply to peterc, 06-03-2001 18:56:48
well I found it , working good now, finally got rid of the keeper for the needle valve return, seems it would not let the valve seat , not leaking,and running fine,thanks for the help
