Sticking in Gear TE 20
rod
09-07-1999 12:29:24
My tractor sticks in first gear a lot and to unstick I must remove shift lever and manually move out of gear the ball on the shifter seems good but the grooves it moves in are worn is there a quick fix for this? any help appreciated
rod
padraig
09-20-1999 14:16:29
 Re: Sticking in Gear TE 20 in reply to rod, 09-07-1999 12:29:24
hthhgfdf
kevin
09-08-1999 05:49:09
My brother had the same problem with his TE-20. You are correct that the problem is in the worn shift rails and the shift lever itself. He took the rails and the shift lever to a machine shop where they built them back up to fit tightly. That solved the problem.
