TO-20 Question and a Tip
David Waymann
05-27-2001 06:06:58
I was working on the brakes and rear axle seals this weekend. Can anyone tell me whether the primary and secondary brake shoes are in the same location on each side? In the IT manual, the right side is shown with the primary shoe below the axle shaft and the secondary shoe above. On the other side, is it the opposite?
I installed sure seals instead of getting into cutting collars, removing bearings, etc. Some of you had posted that the sure seals were somewhat difficult to install. Some posts suggested that beveling the edge on the sure seal aided installation. I purchased 30 inches of 3 inch PVC pipe ($2.00) and was able to drive the sure seals into place. I placed the axle half shaft, wheel studs down, on a piece of 2"X6" and slid the PVC pipe over the sure seal (positioned so the seal end of the sure seal was closer to the splined end of the half shaft). Using a short piece of 2"X4" over the end of the PVC, the seal went in easily with a few solid blows from a 2lb hammer. I re-installed the axle half shafts, adjusted the bearings and will try everything out this morning. I replaced the brake shoes on one side as they were in poor shape. On the other side, I de-greased the oil-soaked shoes and used sand paper to rough up their surface. I adjusted both sets of brake shoes and linkage. I'll let you know if I was successful. Thanks, David (in Michigan)
Duner Wi
05-28-2001 14:17:33
 Re: TO-20 Question and a Tip in reply to David Waymann, 05-27-2001 06:06:58
Shoes would be the same on either side. You say the primary shoe is below the axle shaft then left or right side it would be below the axle shaft.
David Waymann
05-29-2001 08:22:07
 Re: Re: TO-20 Question and a Tip in reply to Duner Wi, 05-28-2001 14:17:33
Duner: Thanks for confirming what I suspected to be true. What caused me to ponder this is that I found the left side was set up opposite to the right side when I went to replace brake shoes. Someone before me must have thought that the primary shoe was on top on the left and on the bottom on the right. I have them set correctly now. Thanks again, David (in Michigan)
David Waymann
05-29-2001 08:19:24
