TO-20 distributor
Ron Crow
05-26-2001 21:27:42
We have a To-20 with a Delco-Remy distributor, model number 1111722 serial number OJ15. I need to know where I can find a schematic drawing to help me understand how it works. We could not get it timed right. It would actually move or would jump. I believe something inside is really worn. Thanks for the help.
Duner Wi
05-28-2001 14:12:20
 Re: TO-20 distributor in reply to Ron Crow, 05-26-2001 21:27:42
Remove cap and rotor.
Turn engine so the points are open.
Wiggle the shaft sideways toward the points rubbing block and see how much slop you have between the shaft and dist. housing.
I bought a set of bushings to put in mine but have not got to it yet. As far as the wiring it is like any old delco,wire from coil to points along with the condenser wire. Good luck!
