Zane Thang
Jack Thompson
05-17-2001 07:20:09
Hey Floks here is a copy of the letter I sent to Mr. Sherman after I recived my "Zane Thang"
Recived my "thang" today and just in time! We had the 1st. rain in over 3 months and it came down in buckets all night, a real "gully washer". I installed the thang in about 30 minutes and truly enjoyed using my "ole freggie"!. Our gravel drive way had ruts 6 inches deep and I was able to cut the stone back over them without cutting the mud. This was impossible before!
Thanks for a good working product. If you need references feel free to call on me!
Thanks Again
Jack
Belive me Folks if ya have a Ferguson system on your tractor you NEED a "ZANE THANG".
steve
05-17-2001 11:12:40
 Re: Zane Thang in reply to Jack Thompson, 05-17-2001 07:20:09
Will the "Zang Thang" work on a TO-30? My TO-30 drives me crazy with a rotary mower on the back. Too low (dragging the ground), then too high, then too low again, etc.... So I bought a set of chains that work but are also a pain.
Will this device work with a TO-30? And, will it stop my lift from "drifting" UP AND DOWN on its own.
-steve
Clark
05-18-2001 08:46:11
 Re: Re: Zane Thang in reply to steve, 05-17-2001 11:12:40
I recently installed a Zane Thang on my TE20 for the same problems you are experiancing. I could not maintain a consistant mowing height and when running down the road it would raise to high and the PTO shaft would start grinding on the mower deck. The Zane Thang cured the problem. Now I set the mower where I want it and it stays there! No more chains! It works great! Better then I'd had even hoped for.
Michael Williams
05-17-2001 15:00:46
You bet it will help. It keeps the implement at the height you set . It really works!
Michael Williams
