To-20 hyd lift
robert
05-15-2001 20:46:09
the hyd lift on my to-20 will not stay in place...if the handle is in one location the lift moves either up or down. if you happen to find a location where the lift will stay stationary after about 10 minutes it bgins to creep. is this an adjustment problem or does the cylinder need work? help!
marlowe
05-16-2001 15:21:34
 Re: to-20 hyd lift in reply to robert, 05-15-2001 20:46:09
i must be real lucky my to-20 3pt. will stay in one spot without any trouble use a three pt. rear blade for grading a 3pt. plow and they all hold a constant height the only thing that would cause your trouble is it is out off adjustment that was the reason the ferguson 3pt. was much better then a ford
gpbob
05-16-2001 12:55:57
What you need is a Zane thing.
http://www.zanethang.com
Jack Thompson
05-17-2001 07:15:54
 Re: Re: to-20 hyd lift in reply to gpbob, 05-16-2001 12:55:57
Ya get ya a "zane thang". I have one and it made a new tractor out of my TO-20! Just do a search for it, Zane has a web page for it.
