Where are the identification plates/serial numbers?
Fred Walter
05-13-2001 22:06:20
I recently purchased a tractor at a farm equipment auction.
My Dad tells me that is is a Ferguson.
Where do I look on the tractor to find out the make/model/serial number?
I need to replace the rear left wheel/axel seal. How big of a job is this? (The d*mn thing wasn't leaking at the auction.)
Phil (VA)
05-14-2001 06:47:55
 Re: Where are the identification plates/serial numbers? in reply to Fred Walter, 05-13-2001 22:06:20
Fergusons normally have a plate on the top of the steering housing that gives the serial number. You can look up the serial number by checking the reference on the left column of this board. If no plate on steering column, look for engine number. It may start with Z120 or Z129 or Z134, etc. Find that and get back with us. A Z120 would be for TO20, Z129 for TO30, and Z134 for TO35, for example. Axle seals are not difficult to replace. Once you find which tractor you have, get a manual (left column of this board, or dealer). MF dealers will have the seals, which are available from several mail order sources also. Hope this helps.
Fred Walter
01-14-2002 12:59:52
 Re: Re: Where are the identification plates/serial numbers? in reply to Phil (VA), 05-14-2001 06:47:55
There is no plate on the steering column.
The engine has the following on it:
Z120A-600 K13W X
What's a TE20 and a TEA20 have?
