Zane Thang
Michael William
05-13-2001 19:39:21
Here is a message I sent to Zane Sherman about the Zane Thang.
'Zane, just a note to let you know how great the Zane Thang is! Got it all hooked up (the pictures are great), got my box blade on and lo and behold, it held it where I wanted it. It worked great on the bush hog too. You have given my Ferguson a new dimension in usefulness. Your product truly does what it says it will do.'
Rich Zlattner
05-15-2001 06:57:37
 Re: Zane Thang in reply to Michael Williams, 05-13-2001 19:39:21
I have a TO-20. When I use my finish mower or landscape rake, they stay right behind the tractor. They never sway or drift. I don't seem to have any need for a Zane Thang. Am I just lucky, or am I missing something? I keep hearing you guys say how great it is, but I don't seem to need it. Any opinions?
Thanks, Rich.
Michael Williams
05-15-2001 07:00:59
 Re: Re: Zane Thang in reply to Rich Zlattner, 05-15-2001 06:57:37
Rich, the Zane Thang controls the height of the implement, not the side to side. You can set your implement to a certain height and it stays there. I have had trouble keeping my box blade and bush hog to the right height. The Zane Thang solves the problem.
Michael Williams
Clark
05-14-2001 10:05:00
I just recently purchased and installed a "Zane Thang", also. It was very easy to install (took me about 10 minutes) and works better then I had even hoped for. I use to use chains on my bush hog, and it was a real pain in the butt. Now I just set it and forget it!
Clark
05-14-2001 10:04:26
Frank Biscardi
05-14-2001 03:58:30
It really is wonderful, isn't it? The only modification I would suggest is to put a thumbscrew (wingnut) on the bolt that attaches to the fingertip control so you don't need a wrench to go back to draft control.
Frank
Clint
05-14-2001 11:50:56
 Re: Re: Zane Thang in reply to Frank Biscardi, 05-14-2001 03:58:30
Just what is a Zane thang and where could I get one
Michael Williams
05-14-2001 13:33:11
 Re: Re: Re: Zane Thang in reply to Clint, 05-14-2001 11:50:56
Here is the link that contains the information about the Zane Thang. It is a product that allows a Ferguson to have position control.
Link
