TO30 water-in-oil
Howard
05-07-2001 19:48:14
Have a TO30 (Z129 engine) that is putting antifreeze in oil, but not getting oil in radiator. Started taking it apart to overhaul it tonite and was wondering if anyone has any suggestions on what to look for to find the problem. Any advice will be appreciated. Thanks
marlowe
05-07-2001 21:43:41
 Re: TO30 water-in-oil in reply to Howard, 05-07-2001 19:48:14
bad head gasket if your lucky or cracked head or block 99 times out of 100 it will be water in the oil not oil in radiator
Bobby
05-08-2001 16:57:53
 Re: Re: TO30 water-in-oil in reply to marlowe, 05-07-2001 21:43:41
If you pull the head you will probably find the problem. If it is a block problem you can salvage most blocks with stainless steel pins and pulling it together. Don't scrap the block. I have pulled several together over the years. Could also be cavitation in the sleeves or the seals at the bottom of the sleeve.
marlowe
05-08-2001 19:47:09
 Re: Re: Re: TO30 water-in-oil in reply to Bobby, 05-08-2001 16:57:53
bobby is sure right about the sleave seals i just plane forgot that it had wet sleeves sorry!!!
Howard
05-08-2001 20:30:24
 Re: Re: Re: Re: TO30 water-in-oil in reply to marlowe, 05-08-2001 19:47:09
Thanks guys for all the help. Finished taking engine out of tractor tonite, but have not tore down bottom end yet. It was getting late and it needs to drain (lots of sludge in pan and bottom end). Should get to the COLD HARD FACTS tommorrow nite. Thanks again and I'll try to post results later.
