TO-30 3-point lift control handle
Gary Bumgarner
05-07-2001 18:13:39
My lift control handle is about 180 degrees out of sync. The finger tip control has to be moved out of the cage, almost straight down toward the ground to make the 3-point hitch lower. Any ideas?
R/ Gary
Ray,IN
05-07-2001 18:48:25
 Re: TO-30 3-point lift control handle in reply to Gary Bumgarner, 05-07-2001 18:13:39
Mark 2 1/2inches down from top of the quadrant. This is where the fingertip control lever should be for the implement to begin dropping. Start by raising the lift w/implement attached. Adjust the master control spring to remove all end play, you should still be able to turn it by hand though. Now loosen the four cap screws that hold the quadrant in place, and move quadrant to rearmost position(the holes are slotted). You should have the fingertip control lever at the 2 1/2inch mark. Slowly move quadrant forward until the implement begins to drop. Tighten the four cap screws. If this does'nt correct your problem, Bobby is right, the problem is caused by something loose/bent inside the hyd. system. I believe in starting with the easiest to fix/adjust when the cause is'nt apparent.
bobby
05-07-2001 18:28:29
could be the moon key on quadrant shaft but most likely is inside the cover. Or the fork has sliped out on one side of the control valve. you could drain the oil and look up at the valve.
