Hyd.loader pump questions
Dave
05-05-2001 08:02:33
Will a crank driven pump that flows 6.3 GPM @1500 max.PSI be adiquate for a loader on TO30?
Dave
Bobby
05-05-2001 20:35:13
 Re: hyd.loader pump questions in reply to Dave, 05-05-2001 08:02:33
Pump volume and psi are determined by the size and the type of ram or cylinder that is being used. the larger the ram or piston area the more volume it will take. the smaller the more psi. it will take. it is a safe bet that if you have a 2.5 in. cyl.or more you probably will work ok. if you have a modern cylinder set up you may be short on pressure.
Dennis
05-05-2001 08:22:25
Can't say what my crank driven Wagner loader pump puts out because there's no spec plate on it but I can't imagine that it would be any more than that. It runs two lift rams AND a tipper ram very adequately.
