TO-20 Brake Drum Dust Seals
David Waymann
05-02-2001 06:42:17
Hi all: I was doing some maintenance on my '49 TO-20 over the weekend and discovered that I needed to replace the brake shoes on one axle. As I was inspecting things, I realized that there was a felt dust seal on the brake backing plate. I checked with the local M-F dealer and the parts book shows this dust seal, but it is no longer available. Is this dust seal necessary? Has anyone found a suitable replacement? Thanks in advance for your help, David (in Michigan)
Bobby
05-02-2001 19:42:52
 Re: TO-20 Brake Drum Dust Seals in reply to David Waymann, 05-02-2001 06:42:17
It was felt. about 3/8 thick. if you have not removed them don't. check rear axle play and tighten to specs. this will lower the drum into the grove a little and will be ok. if you are using the unit for just tinkering don't worry it will be a long time till it causes any problem.
David Waymann
05-03-2001 05:34:17
 Re: Re: TO-20 Brake Drum Dust Seals in reply to Bobby , 05-02-2001 19:42:52
Bobby: Thanks for the reply. I have not removed the felt dust seals, but more than 50% of the seal had fallen off each side. Are you aware of a source for replacement dust seals? If I adjust axle play (if necessary) and remove what remains of the dust seals, will this create problems? I use my tractor primarily for mowing, blading (mostly snow) and some hauling (trailer). Thanks, David
Bobby
05-04-2001 20:20:34
 Re: Re: Re: TO-20 Brake Drum Dust Seals in reply to David Waymann, 05-03-2001 05:34:17
No it will not cause problems unless you were to run in extreme wet conditions and then you may experience some loss of brake effectiveness. there are many out there without the seals. The felt is about the same as a door seal from a good hardware store. something like a draft seal for a door may work just trim, it is not a crutial fit.
