To 30 trans. is leaking
Charles
04-28-2001 12:42:29
This morning I changed hydraulic oil now I have two leaks. On bottom of trans is what looks like two cotter pins hanging out does anyone know what these are and how to stop them from leaking ? thanks Charles
David Waymann
04-30-2001 12:35:01
 Re: To 30 trans. is leaking in reply to Charles, 04-28-2001 12:42:29
Charles: Hi. The cotter pins are to keep the drainage holes under the transmission from being blocked (plugged). This was in case a leak developed, the clutch would not then be submerged in transfluid that leaked into the trans case-clutch housing. I suspect that you either have a rear engine seal leak or a transmission seal leak (you should be able to tell by the fluid type). Either way, the tractor will have to be split to replace these seals. If it is just a minor leak, I would leave well enough alone. I've had a leak in mine for the past 6 years (its worse in warm weather or after I've run the tractor for a while). Hope this helps, David
marlowe
04-28-2001 14:13:14
p.s. sure hope you used the right oil ??? mineral oil 85 90 wt. M1103
marlowe
04-28-2001 14:22:37
 Re: Re: To 30 trans. is leaking in reply to marlowe, 04-28-2001 14:13:14
three drain plugs it holds about 7 gal.
marlowe
04-28-2001 14:08:50
the cotter pin holes are for leakage but it sounds like you might have over filled it??
Charles
04-28-2001 17:38:55
 Re: Re: To 30 trans. is leaking in reply to marlowe, 04-28-2001 14:08:50
Thanks Marlowe I used M1103 I got it from the massy dealer I may have over filled I will keep a eye on It once again Thanks Charles
